Maintenance Tips & Tricks – 1999 – #17
By Plant Engineering Staff September 1, 1999
Rough shaft alignment
Problem : Two shafts must be aligned, but no alignment instruments are available.
Solution : Wrap a short piece of #12 AWG solid copper insulated wire tightly around each shaft. Strip about an 1 in. of insulation off the “pointer” ends, and bend the ends at 90-deg angles toward each other. Line up the ends with a 1/8-in. gap between them. Now you can align the shafts, rotating them by hand and keeping the pointers aligned while adjusting the equipment mounts.
Contributor : Don LeSage, Fred Usinger, Inc., Milwaukee, WI; 414-276-9100
List of Tips & Tricks
Plant Engineering
