Continue to Site
Maintenance Tips & Tricks – 1999 – #1
By Plant Engineering Staff September 1, 1999
Trapping Elusive Pressure
Problem : During off-hours, a fluid pressure fluctuates (example: fire water line). It’s desired to know the maximum pressure, but there is no chart recorder or other trending device on the line.
Solution : Make a simple pressure trapping gauge setup. This arrangement traps the highest pressure applied to it. Reset it by momentarily opening the bypass valve so that it can equalize to the current process pressure.
For best results, use a vertically mounted, soft-seat check valve with the spring removed. Contributor: Ralph Dewey, Solvay Polymers Corp., Deer Park, TX; 713-307-3784
List of Tips & Tricks
Plant Engineering
