Maintaining hydraulic fluids
Maintaining hydraulic fluids is an important job that can reduce or eliminate many problems. This article describes how to keep fluid contamination to an acceptable minimum; external and internal contamination sources; portable instruments used to quickly and accurately measure particle contamination; maintenance measures and more.
Plant Engineering – December 2000 FLUID POWER MAINTENANCE Cover feature: Maintaining hydraulic fluids Joseph L. Foszcz, Senior Editor, Plant Engineering Magazine Sidebar 1: Sources of generated contamination Sidebar 2:
Clean hydraulic fluid is the best friend any hydraulic system can have. It transmits pressure, lubricates components, suspends contaminants, and keeps the system cool. Unfortunately, when this fluid gets too contaminated it can wreak havoc by causing components to wear, seals to leak, and valve passages to block. Much present-day thinking about hydraulic systems suggests that filters be changed when their indicator says so, fluid can be added straight from a drum of “clean” oil, and if a system is running, leave well enough alone ( Fig. 1 ). The truth is that maintaining hydraulic fluids is an important job that can reduce or eliminate many problems. Key components of hydraulic fluid maintenance are reducing, but never eliminating, sources of contamination and oil degradation and regular fluid monitoring. Studies have shown that up to 55% of hydraulic components fail when the contamination level is too high. Monitoring hydraulic systems for contamination can provide an early warning of component or filter failure, helping to avoid unplanned or catastrophic downtime. Sources of contamination Built-in The amount of contamination removed during system flushing depends on the effectiveness of the filters used and the temperature, viscosity, and turbulence or velocity of the flushing fluid. Unless high velocities are reached, much of the contamination will not be dislodged until the system is in operation. Depending on filter location, catastrophic component failure is a possibility. A running-in period is essential for any new or rebuilt hydraulic system. Ingressed Whenever a system component is opened for maintenance, there is an opportunity for contamination to enter. All possible care should be taken to ensure that open ports are covered or plugged and component rework is done in a clean area. Cylinder rod wiper seals are not 100% effective in removing a thin oil film and fine contamination from cylinder rods. Environmental dirt that sticks to the extended rod is drawn into the cylinder and enters the hydraulic fluid. Generated In a system operating with clean fluid, all components, especially pumps, create a small amount of particles. If these particles are not quickly captured, elevated contamination levels cause the number of additional generated particles to increase at a highly accelerated rate. New oil Detection Visually inspecting an oil sample by holding it up to a light does not provide any real measure of contamination. The human eye, even with perfect vision, cannot distinguish single particles below 40 microns in size ( Fig. 3 ). The most complete determination of hydraulic oil contamination is done in a lab. Samples must be taken in a certified superclean glass container. Just certified clean containers, which are biologically clean, are not necessarily free of solid particulate. ISO 3722 should be followed for certifying that bottle cleanliness is free of solids. The sampling method should be selected on the basis of the results desired. If representative particle size distribution is required, a dynamic sample from a tubing or pipeline must be taken. A static sample, from the reservoir, is used for particle counts, viscosity measurements, and water and other chemical analysis. Laboratory tests produce a detailed analysis of hydraulic fluids.
Plant Engineering |
