Machine perimeter guarding modular system
Folding Guard’s Saf-T-Fence machine perimeter guarding modular system offers a customized alternative to permanent walls
By SOURCE: Folding Guard May 30, 2011
Folding Guard has improved their Saf-T-Fence Machine Perimeter Guarding modular systems. A standard system consists of posts, panels, doors and hardware, and the company offers ample options in each. There are three post heights, six styles of doors, and over 30 pre-fabricated wire mesh panels and accessories. All bolt together, and are built for exact fit and easy assembly.
Saf-T-Fence’s mesh openings, heights, clearances and tolerances can all help companies meet OSHA, ANSI, CSA, and EN safety regulations.
Folding Guard has also updated Saf-T-Fence partitions, a low-cost alternative to building permanent walls. Each panel is built on a tough, 1-1/2” x 1-1/2” x 14-gauge steel frame. Wire mesh is securely welded at each intersection, creating rectangular openings. Saf-T-Fence partitions deliver security, visibility, and flexibility.
Due to the nature of modular systems, configuring a custom solution is simple to install and versatile enough to expand easily. Should floor plans change, they can be easily relocated and reinstalled in any space. Options are available in doors, locks, colors, custom sizes and configurations.
– Edited by Gust Gianos, Consulting-Specifying Engineer, www.csemag.com
