Lubricants
By Plant Engineering Staff November 29, 2006
CorrSurface Protect (CSP) coatings and lubricants are designed for maintenance of critical equipment used by corrugated box manufacturers. CSP 3560 coating pretreats trays, allowing ink and starch to be hosed off easily and eliminating the need for pan scraping. CSP 2224 treats double-backer hot plates, shortening board scoring and production downtime due to scraping. CSP 310is a water-based lubricant that eliminates staining of board that often results from the use of oil-based lubricants. Additionally, it has been shown to extend run life of blades by as much as 30 percent, the company reports.
DuPont
www.dupont.com
