Lube prevents rust
SiliKroil is formulated with silicone for maximum penetration and lubrication, and dissolves rust by breaking down crystals of iron oxide, which allows corroded parts to loosen easily.
By Staff December 1, 1999
SiliKroil is formulated with silicone for maximum penetration and lubrication, and dissolves rust by breaking down crystals of iron oxide, which allows corroded parts to loosen easily. The lubricant creeps into openings as small as a millionth of an inch and leaves behind a water-repellent coating to prevent corrosion and protect against rust.
Kano Laboratories, Inc.
www.kanolabs.com
Circle 254
