Low-profile sanitary screener
The VIBROSCREEN FLO-THRU model K24-1FT-SS employs two unbalanced-weight gyratory motors mounted on opposing exterior sidewalls of the unit, reducing minimum height requirements.
The VIBROSCREEN FLO-THRU model K24-1FT-SS employs two unbalanced-weight gyratory motors mounted on opposing exterior sidewalls of the unit, reducing minimum height requirements. Mounted on suspension brackets, the design also allows vertical alignment of the top inlet and bottom outlet, facilitating on-size material descent through the screen in a straight-through path at high rates into mobile vessels on the plant floor. Oversize material is ejected through a spout at the periphery of the screen. The 24-inch diameter screener is constructed of stainless steel finished to 3-A, FDA, BISSC, and other sanitary standards.
Kason Corp.
