Low-maintenance bearings
NA Poly-Round bearings are USDA-accepted and lubricant-free Class 3 plane bearings.
NA Poly-Round bearings are USDA-accepted and lubricant-free Class 3 plane bearings. They can operate at temperatures up to 200 F and accommodate loads up to 2,000 PSI and speeds up to 1,000 RPM on a 1-inch shaft. The bearings are designed to avoid catastrophic failures and facilitate planned maintenance cycles. Typical applications for the bearings include sprocket-driven conveyor belts, processing equipment, dumpers and packaging equipment used in meat and poultry processing, bakeries, smokehouse and freezer feed conveyors. EDT Corp. www.edtcorp.com
