Literature Offers – 2002-03-11
Lift tables
An extensive line of scissor lift tables designed to improve productivity and worker safety are featured in a catalog. Ideal for machine feeding, work positioning, assembly, order picking, and pallet loading, LS Series Backsaver lifts are available in basic sizes and capacities to lift and position loads to 6000 pounds at heights up to 56 in.
Southworth Products Corp.
Write 316 on PE card
Test and measurement
Keithley’s electronic test and measurement instrumentation and data acquisition hardware and software are detailed in a full-color catalog. Products include digital multimeters, switch and measure systems, switch and control products, broadband signal routing systems, and power sources.
Keithley Instruments, Inc.
Write 317 on PE card
Clamps
A full-line catalog contains information on an extensive range of stainless steel clamping, identification and sign mounting systems, installation tools, hose fittings, and accessories.
BAND-IT
Write 318 on PE card
Fuses
A brochure highlights medium voltage expulsion fuses, which are offered in a wide range of refillable and replaceable expulsion power fuses. The application, capabilities, and reliability of the expulsion fuses are discussed, as well as current limiting fuses.
Eaton Cutler-Hammer
cutlerhammer.com
Write 319 on PE card
eCatalog
Design engineers can easily access necessary information on specific Warner Electric products, including part numbers. Engineers can refine their search to include downloadable drawings and product specifications and can request a quotation from an authorized distributor.
Warner Electric
Write 320 on PE card
Power transmission
A brochure gives descriptions of clutches, brakes, gearing, controllers, and gear drives and points out which ones are ideal for a wide range of applications in various industries.
Colfax PT Group
colfaxpt.com
Write 321 on PE card
Strut installation
The CADDY Corner newsletter informs readers about the STS clamp for assembling back-to-back struts without welding, a timesaving alternative, and the SLICK strut nut, which eliminates the need for spring nuts.
ERICO, Inc.
Write 322 on PE card
Industrial wiring
A CD-ROM allows users to access information from Leviton’s IPD-2.01 catalog and provides intuitive icons, modular specification tables, and color-coding techniques. To make searches easier, visible navigation aids, information pointers, grade types, and product types are furnished.
Leviton Manufacturing Company
Write 323 on PE card
Safety
More than 280 manufacturers are represented in the VWR International 2001/2002 Safety catalog, which details thousands of products for laboratory and industrial safety uses. Ordering information, photography, and specifications are included.
VWR International
Write 324 on PE card
Conveyance system
Superail is a low-profile, high-impact conveyance system available in standard four-foot sections. Each section consists of three staggered rows of ball bearing rollers handling loads of up to 1000 lb per linear inch and compensates for uneven or damaged containers.
Custom Automation, Inc.
customautomationinc.com
Write 325 on PE card
Welding end prep tools
A variety of photographs are used to illustrate the performance of portable welding end prep tools. Specifications and recommended applications are included, along with available accessories.
ESCO Tool
Write 326 on PE card
Digital sensors
The Keyence Sensor Solution guide helps users and specifiers of digital sensors select the best product for their application and get it up and running in the shortest possible time.
Keyence Corp. of America
keyence.com
Write 327 on PE card
Safety enclosures
The expansion of Increased Safety products includes three styles of terminal enclosures, high voltage junction boxes, control enclosures, and enclosures with intrinsically safe terminals. In addition to the catalog, a searchable CD is available.
Adalet
Write 328 on PE card
Hoses
Parker’s 451TC and 451ST 3000 psi constant working pressure hoses with abrasion-resistant Tough Cover or Super Tough cover are featured in a bulletin.
Parker Hose Products
parkerhose.com
Write 329 on PE card
Controls and gages
Dwyer Instruments, Inc. discusses more than 3600 innovative products, including the Series UV Ultra-View Polysulfone flowmeter, which measures high temperatures and high pressures.
Write 330 on PE card
Electrical products
Electrical products and accessories are divided into six sections for easy reference, including Conduit Bending, Hand Tools, and Hole Cutting.
Gardner Bender
Write 331 on PE card
Flow meters
In addition to covering in-line flow meters, probes, and switches, “Measuring up to the highest standards in flow measurement” describes techniques for measuring flows of gases, liquids, slurries, and homogeneous solids.
Thermal Instrument Company
Write 332 on PE card
