Literature Offers
By Staff October 1, 2001
AC motors
Rockwell Automation showcases 1/3 to 2500 horsepower inverter-duty motors in the RELIANCE variable speed AC motors brochure. In addition to 16 photographs, the 6-p brochure includes a chart depicting motor styles and features available, the rating capability and typical applications of small RPM AC, V*S Master and large AC Global Series, and variable torque product lines.
Rockwell Automation
reliance.com
Circle 316
Automation products
Scientific Technologies, Inc. offers a 2001-2002, four-color guide featuring nearly 90 automation products in nine categories, including ultrasonic sensing, capacitance level detection, and continuous level measurement of liquids and solids. New pressure sensing and displacement/velocity detection products are also included.
automationsensors.com
Circle 317
Breathing Apparatuses
3M Occupational Health & Environmental Safety Division introduces its new line of Air-Mate Self-Contained Breathing Apparatuses (SCBAs) in a four-color guide. Specifications and ordering information are offered for Air-Mate 2000 SCBAs, Air-Mate Combination Escape SCBAs/Supplied Air Respirators (SARs), and Air-Mate SCBAGs.
3M
3M.com/occsafety
Circle 318
Surface preparation
“Surface Preparation Guide” is a new Sherwin-Williams brochure that highlights the proper surface preparation methods for substrates and SSPC surface preparation standards. Methods include surface cleaning, mechanical service preparation, and chemical surface preparation.
Sherwin-Williams Company
sherwinwilliams.com
Circle 319
Dryers
A new brochure by Van Air Systems, Inc. features Freedom dryers, which are aimed at minimizing high energy costs and moisture problems. The dryers can be installed indoors or outdoors, require no electricity, and can be utilized across a range of applications, including cement plants and dust collectors.
vanairsystems.com
Circle 320
Flange protectors
Niagara Plastics Company introduces its new expanded range of FC Series stud-hole flange protectors. The flange protectors are offered in two styles, one for use on 125-lb and 150-lb flanges, and the other for use on 300-lb, 400-lb and 600-lb flanges.
niagaraplastics.com
Circle 321
Noise control
Tamer Industries showcases custom enclosures with a wide range of applications, including compressors, stamping presses, and screw machines. Enclosures create a cleaner and safer working environment.
Tamer Industries
tamerind.com
Circle 322
Analysis instruments
Shimpo Instruments provides an overview of its speed product family line and leaders in each category, including handheld contact tachometers, counters, stroboscopes, and sensors. Shimpo’s MRO inspection instruments are used in applications such as compressors and visual freezing of motion.
Shimpo Instruments
shimpoinst.com
Circle 323
Water jets
“Before” and “after” photographs illustrate the benefits of water jetting. In addition to demonstrating how high-pressure water jetting solves product removal problems, the brochure also shows how water jetting can clean parts, conveyors, fixtures, skids, and clogged screens.
NLB Corp.
nlbcorp.com
Circle 324
Single-element filters
The P-2000 Series filter flyer for single-element filters is now available through Pneumatic Products. Benefits of the P-2000 Series filters include contaminant removal efficiencies and low differential pressure drop, all at affordable prices.
Pneumatic Products
pneumaticproducts.com
Circle 325
Watertube boilers
ABCO Industries, Inc.’s brochure explores the advantages of package watertube boilers, which feature no-refractory designs and 100% membrane walls. Boilers are engineered to meet specific application criteria, including low or ultra low CO and NO x emissions.
abcoboilers.com
Circle 326
Compressed Air Dryers
With prefilters and afterfilters becoming standard, Kemp’s Series 60 Dryer System provides high-quality compressed air with -40F and -100F pressure dew points. It’s also particulate-free to an absolute rating of 0.9 micron and a residual oil content of &0.001 ppmw.
Kemp
cmkemp.com
Circle 327
Hose reels
A catalog features information and specifications on popular stainless steel hose reels offered by Hannay Reels. The four-color catalog includes narrow-frame reels for confined spaces, compact models for pressure washing, and heavy-duty reels for industrial settings.
Hannay Reels
hannay.com
Circle 328
Valves
Red Valve has updated and expanded its brochure on the Series G Knife Gate Valve, a product that includes special features for drop-tight sealing. A precision-buffed gate and two bosses welded to the valve seat is one example. The Series G is available in sizes to 144 in.
Red Valve
redvalve.com
Circle 329
Mounted bearings
The Accu-Loc line of concentric-locking mounted bearings is the focus of a 42-p catalog by AMI Bearings, Inc. The Accu-Loc bearings are designed for low vibration, low noise, and low friction applications. The catalog also includes data on AMI’s newly patented, non-contact, free-spinning configuration.
AMI Bearings, Inc.
amibearings.com
Circle 330
Power controllers
Information on Watlow’s power controller product line and an easy-to-use application chart are included in the company’s latest brochure. Watlow power controlling devices can minimize temperature extremes and increase heater life up to 20 times.
Watlow Electric Manufacturing Co.
watlow.com
Circle 331
Pipe cutting and beveling
Mathey Dearman’s 12-p product brochure includes information on pipe cutting and beveling machines, pipe alignment and reforming clamps, welding electrode and flux ovens, and pipefitter tools. It’s offered in seven languages.
Mathey Dearman, Inc.
mathey.com
Circle 332
Tubing and hose
A brochure titled “Products & Services Guide” features the products and custom capabilities of NewAge Industries. Tubing and hose items, fittings, clamps, and custom fabrication options are discussed in this miniature version of NewAge’s complete catalog.
NewAge Industries, Inc.
newageindustries.com
Circle 333
Valve Automation
ABB’s brochure covers a range of valve automation products, including electrical modulating and on/off actuators, electropneumatic signal converters and positioners, damper drives, and pneumatic and electropneumatic instruments.
ABB Instrumentation
us.abb.com
Circle 334
Want this article on your website? Click here to see how ContentStream® can make that happen.
