Liquid filtration bags
The construction of DURAGAF filter bags delivers filtration performance with a service life two to five times greater than standard felt media filter bags, the company claims. The filter bags come in two extended-life materials: polypropylene and polyester. The materials use a fiber blend with a finer fiber diameter and a higher weight than ordinary media. The bags feature an all-welded construction to eliminate the process media bypass that can occur in sewn filter bags. This construction uses a proprietary fabric-welding technology to produce a seam that is designed to stand up to demanding applications without failure.
Eaton Filtration LLC
www.filtration.eaton.com
