Linear encoder
The LIDA 200 series is a high-quality, low-cost exposed linear encoder package. The encoders can be simply and quickly mounted via a scale tape, which is supplied in rolls with reference marks and cut to the desired length by the customer, then secured directly on the mounting surface by means of its adhesive film.
The LIDA 200 series is a high-quality, low-cost exposed linear encoder package. The encoders can be simply and quickly mounted via a scale tape, which is supplied in rolls with reference marks and cut to the desired length by the customer, then secured directly on the mounting surface by means of its adhesive film. As an alternative, it can also be mounted by means of a scale tape carrier extrusion, along with supplied adhesive and clamping mechanism for thermal effects.
Heidenhain
www.heidenhain.com
