Limit switches for rugged industrial environments
AutomationDirect's F25 Series NEMA limit switches consist of three modular, interchangeable, plug-in components: operating head, switch body, and wiring receptacle.
By AutomationDirect March 30, 2017
AutomationDirect's F25 Series NEMA limit switches consist of three modular, interchangeable, plug-in components: operating head, switch body, and wiring receptacle. Courtesy: AutomationDirectAutomationDirect’s F25 Series NEMA limit switches are NEMA 3, 3S, 4, 4X, 6, 6P, 13, and IP67 rated for operation in a variety of rugged industrial environments. All F25 Series NEMA limit switches consist of three modular, interchangeable, plug-in components: operating head, switch body, and wiring receptacle. Operating heads (side rotary, top and side push, and wobble stick) are mounted on top of the switch body in any of four positions. The plug-in component design allows a damaged switch to be easily replaced in the field without rewiring (the wiring remains intact in the receptacle). Nine versions of side rotary limit switches are available with fixed and adjustable length stainless steel levers and Nylatron or metal rollers. Also available are adjustable spring stainless steel rod and 6-inch Nylatron loop side rotary switches. Six versions of metal plunger (side push and top push) limit switches are available; along with three types of 360-deg rod and spring (wobble head) limit switches.
AutomationDirect
www.automationdirect.com
– Edited by CFE Media. See more Control Engineering energy and power products.
Want this article on your website? Click here to sign up for a free account in ContentStream® and make that happen.
