Lighting
Click on the above link to see Product of the Year finalists in this category.
By Staff November 1, 2001
Note to our readers: Product of the Year finalists are listed below. To view the products, please download this pdf file . It may take a minute or two to load.
T8 lamp saves energy
The T8 Watt-Miser is an environmentally responsible, energy-saving T8 fluorescent lamp that operates on existing electronic instant-start ballasts. The TCLP-compliant lamp offers improved color and energy savings of 6% over standard T8 lamps. When used with the Ultra Ballast, 11% energy savings is achieved for those who choose to replace existing T8 lamps and ballasts. GE Lighting; www.GELighting.com
TO VOTE, WRITE 13 ON BALLOT
For more information, write 13 on card
HPS shines white
MasterColor HPS-Retro White lamps replace old HPS lamps. While conventional HPS lamps have a low color rendering index (CRI) and emit a dull yellow light, this lamp offers a crisp white light with a CRI of 90. Retrofitting is easy because the lamps operate on standard HPS ballasts. The key to its color rendering is the ceramic arc tube technology, which combines the white light of metal halide with PCA technology. Philips Lighting Co.; www.lighting.philips.com
TO VOTE, WRITE 19 ON BALLOT
For more information, write 19 on card
Dual wall switch senses light levels
The WI-300 dual relay wall switch uses passive infrared (PIR) to turn lighting on and off based on occupancy and ambient light levels. With two separate relays, it is capable of controlling two independent lighting loads or circuits simultaneously. The switch features two auto/off pushbuttons on the front of the sensor that enable manual or automatic operation. It has a built-in light level sensor that affects the secondary relay, allowing for daylight control. The Watt Stopper; www.wattstopper.com
TO VOTE, WRITE 41 ON BALLOT
For more information, write 41 on card
Transfer device switches lights to generator power
The GTD is a generator transfer device for fluorescent emergency lighting fixtures. It works in conjunction with a generator to power fluorescent emergency lighting regardless of fixture wall switch position. It senses the loss of normal power, bypasses the wall switch, and supplies generator power directly to the ac ballast. The transfer device allows users to save energy and money. The Bodine Co., Inc.; www.bodine.com
TO VOTE, WRITE 82 ON BALLOT
For more information, write 82 on card
Metal halide lamps use weldless mounts
The Uni-Form 300 Watt pulse start metal halide system with tipless formed body arc tube provides color uniformity that is equal to ceramic metal halide. The lamps incorporate a patented weldless mount design and are available in ED28 and ED27 jackets, clear and coated versions, and MP shrouded versions that pass the ANSI containment test. Venture Lighting International; www.venturelighting.com
TO VOTE, WRITE 93 ON BALLOT
For more information, write 93 on card
Lighting control system is web-enabled
The POWERLINK G3 lighting control system automatically switches off lighting during periods of nonoccupancy. System does not require additional equipment space and can be installed into existing panelboards. It has Ethernet communication capabilities, allowing web-based control and remote access to equipment information over existing building automation networks. Square D/Schneider Electric, Power Management Div.; www.SquareD.com
TO VOTE, WRITE 161 ON BALLOT
For more information, write 161 on card
Flashlight shines through smoke, fog, mist
The Survivor is a Division 2 safety approved, rechargeable, right-angle flashlight featuring a “black dot” xenon bulb with Smoke Cutter optics that penetrate smoke, fog, and mist with up to 25,000 candlepower. It has a steel hinged door and latch for quick battery changes. Charging system allows 1.7 hr continuous run time by allowing simultaneous charging of the light and a spare battery. Streamlight, Inc.; www.streamlight.com
TO VOTE, WRITE 182 ON BALLOT
For more information, write 182 on card
Want this article on your website? Click here to sign up for a free account in ContentStream® and make that happen.
