Continue to Site
Lighting – 2005-08-01
By Staff August 1, 2005
Lighting management
DmF6 series inverter is designed to power up to six cold cathode fluorescent lamps with combined lamp power up to 60 w, and providing a starting voltage up to 2400 V, with full flicker-free brightness control. Inverters feature an optimized form factor, high efficiency, onboard transformers, and onboard connectors for direct connection to the display. Six mounting holes make installation quick and easy. For dimming, an external enable/disable control and an onboard analog-controlled pulse width modulator provide flexibility.
Endicott Research Group www.ergpower.com Write 310 on PE card
