Level transmitter
The MT5200 is designed for level measurement in bulk solids applications. A concentric waveguide directs the radar beam, alleviating divergence problems and echoes in tanks with narrow openings. Unaffected by dust or feed flow the MT5200 accurately measures materials with dielectric constants as low as 1.
By Staff January 1, 1970
The MT5200 is designed for level measurement in bulk solids applications. A concentric waveguide directs the radar beam, alleviating divergence problems and echoes in tanks with narrow openings. Unaffected by dust or feed flow the MT5200 accurately measures materials with dielectric constants as low as 1.3. An integrated graphic display provides easy viewing of waveform screens and the user-friendly setup menu supports a wide range of languages for quick setup in virtually any region of the world. The two-wire, loop powered design reduces wiring costs and provides a strong signal over distances. The MT5200 transmitter has no moving parts and, therefore, requires virtually no maintenance. It takes accurate level measurements in a wide range of application environments.
K-TEK
www.ktekcorp.com
