LED driver boards
Available in two varieties, Smart Force LED driver boards provide compact, full-function LED drivers with a range of dimming options, a wide input voltage, full brightness and enable control for use with industrial LCDs. The SFDL Series provides high-efficiency power with a maximum current of 180-mA to LED rails used in LCDs up to 12.
Available in two varieties, Smart Force LED driver boards provide compact, full-function LED drivers with a range of dimming options, a wide input voltage, full brightness and enable control for use with industrial LCDs. The SFDL Series provides high-efficiency power with a maximum current of 180-mA to LED rails used in LCDs up to 12.1-inches diagonal. It also provides an onboard PWM dimming ratio of 1,000:1 and external PWM dimming to 5,000:1. The SFDC series has a maximum current of 1,000 mA for high-power HBLED backlight rails used in LCDs up to 20.1-inch diagonal.
Endicott Research Group
www.ergpower.com
