Leakage current meter
The TRMS Clamp-On Leakage Current Meter Model 565 is designed to measure low AC currents, which are typically leakage currents in ground conductors. Low currents are measured using the 60mA and 600mA ranges. Leakage current measurements up to 600mA with up to 10µA resolution, on a ground conductor or through the vector sum on multi-conductors, can be accomplished.
By Staff December 1, 2005
The TRMS Clamp-On Leakage Current Meter Model 565 is designed to measure low AC currents, which are typically leakage currents in ground conductors. Low currents are measured using the 60mA and 600mA ranges. Leakage current measurements up to 600mA with up to 10git backlit LCD.
AEMC Instruments www.aemc.com Write 304 on PE card
