LCD monitor
The Stealth' VU SV-1700-HB high brightness LCD monitor is a sunlight readable display designed to operate in extreme ambient light conditions. The 17-inch diagonal monitor has a brightness rating of 1300 Nits, roughly 5 times the brightness of a commercially available desktop monitor. It meets the NEMA 4/IP 66 standards intended for indoor or outdoor use primarily to provide a degree of protect...
The Stealth’ VU SV-1700-HB high brightness LCD monitor is a sunlight readable display designed to operate in extreme ambient light conditions. The 17-inch diagonal monitor has a brightness rating of 1300 Nits, roughly 5 times the brightness of a commercially available desktop monitor. It meets the NEMA 4/IP 66 standards intended for indoor or outdoor use primarily to provide a degree of protection against corrosion, windblown dust and rain, splashing water, and hose-directed water. The all-stainless steel enclosed LCD Monitor is built to withstand the demanding effects of harsh environments typically encountered in outdoor environments, plant floors, and marine/mobile applications. The display is capable of running resolutions up to its native mode of 1280 x 1024 pixels.
Stealth Computer Corp. www.stealthcomputer.com Write 309 on PE card
