Laser process heads for high-speed cutting applications
The G6 series and PHF-25 laser process heads have medium and high output powers that are ideal for cutting applications and laser welding of plastic.
The G6 series laser process heads are designed for fiber lasers with a high output power between 4 kW and 5 kW and are used for high-speed cutting applications. The G6 series compartments make it easy to change the optics quickly for adjusting the focal distance. The PHF-25 series is made for a medium power output of up to 2 kW. This series features a compact design and easy handling through an SMA fiber connection. One application in this power range includes the laser welding of plastic.
Laser Components
