Laser marking system
The MP2, a diode pumped solid state (DPSS) laser marking system, is ideal for applications that require high resolution and where speed throughput is not required.
By LNA Laser June 1, 2016
The MP2, a diode pumped solid state (DPSS) laser marking system, is ideal for applications that require high resolution and where speed throughput is not required. Courtesy: LNA LaserThe MP2, a diode pumped solid state (DPSS) laser marking system, is ideal for applications that require high resolution and where speed throughput is not required. It features a DPSS laser, laser beam scanning optics (galvanometer), control electronics, and marking software. The laser provides a pulse duration of 3 nsec, high peak power of 30 kW, and runs on 24 VDC (6 Amps). The 1064 nm infrared wavelength is well suited for laser marking a wide range of materials such as: metals, plastics and some organics and can be used in a variety of industries.
LNA Laser
www.lnalaser.com
