Laser diode series for electrical, maintenance applications
Laser diode series features an emission wavelength of 520nm for embedded solutions, cameras, and head-up displays.
By Laser Components August 26, 2015
Laser diodes with emission wavelength of 520nm for embedded solutions, cameras, and head-up displays. Courtesy: Laser ComponentsThe PL 520 monomode laser diode is an efficient laser source in both cw and pulsed operation. In cw operations, this green laser diode has an output power of 50 mW and is suited for use in embedded solutions, cameras, and head-up displays. The PLT5 520 model is housed in a TO-56 housing because a photodiode for power control purposes is integrated. PL 520 and PLT5 520 both feature a high modulation bandwidth. The PLP 520 multimode laser diode can be used in laser projectors in home entertainment systems and applications that require high efficiency. The output power is 120 mW and features thermal stability.
Laser Components
www.lasercomponents.com
