IP20 block I/O system
The Ethernet Modbus TCP (UDP) connectivity with the IP20 BradControl block I/O system connects industrial I/O devices to a PLC or PC controller over industrial networks. The TCP (UDP) network adapter operates as a slave device in an Ethernet control system, gathering signals and data from local field devices through the expansion modules. The network adapter module manages all communications with the expansion modules and supplies dc power to the attached local processors. Standard DIN-rail mounting adds flexibility to the design.
Woodhead Industries, Inc.
www.woodhead.com
