IoT gateway and edge processing device
The Zen IoT is a gateway and edge processing device that is designed to enable discrete industrial hardware to be connected to the Cloud.
By Define Instruments November 21, 2016
The Zen IoT is a gateway and Edge Processing Device that is designed to enable discrete industrial hardware to be connected to the Cloud. Courtesy of: Define InstrumentsThe Zen IoT is a gateway and edge processing device that is designed to enable discrete industrial hardware to be connected to the Cloud. As an Edge Processing Device, the Zen IoT is also able to perform calculations on collected data before transmitting to the Cloud. The device converts process signals direct to wireless with no other devices required. It is designed with an input that accepts various industrial signals: TC, RTD, mA, mV, V, and Pulse. The unit also supports a wide range of communication protocols including Modbus and MQTT. The Zen IoT’s physical connections include Ethernet, WiFI, 3G/4G cellular modems, RS485, and Bluetooth. The customizable Zen IoT has its own WiFi port and connects with Transport Layer Security (TLS).
Define Instruments
www.defineinstruments.com
Want this article on your website? Click here to sign up for a free account in ContentStream® and make that happen.
