Interlock switch
The T4012 interlock switch features a compact, glass-filled NEMA 6 thermoplastic housing, making it suitable for use in most applications, including washdown environments. When used with the optional stainless steel actuator, these switches are designed to provide a minimum of two million actuations in demanding environments.
The T4012 interlock switch features a compact, glass-filled NEMA 6 thermoplastic housing, making it suitable for use in most applications, including washdown environments. When used with the optional stainless steel actuator, these switches are designed to provide a minimum of two million actuations in demanding environments. Two- or four-contact pole versions are available, with the four-contact-pole version providing two poles for dual channel safety monitoring and two poles for status monitoring. A rotatable head offers eight possible actuator entry points for versatile setup. Optional slide bolts facilitate easy installation and are robust enough for use with heavy doors. A slotted hole in the bolt permits attaching multiple padlocks for an additional level of safety.
Scientific Technologies, Inc.
www.sti.com
