Interesting fingerprint
Problem: You can see that Allen screw in the hole just below the surface, but can't tell what size wrench to use.
By Staff March 1, 2000
Problem: You can see that Allen screw in the hole just below the surface, but can’t tell what size wrench to use. Is there a way to determine the right tool without using the trial-and-error method?
Solution: Push your finger into the top of the setscrew. The impression made on the fingertip can then to matched to the proper wrench size.
Contributor: Tom Pivarnik, Substation Mechanic, PSE& G Co., Somerset, NJ
Want this article on your website? Click here to sign up for a free account in ContentStream® and make that happen.
