Instruments & Controls
By Staff February 10, 2004
Intelligent IR camera sounds alarms
ThermoVision A20 intelligent infrared (IR) camera allows users to remotely monitor and instantly identify thermal anomalies and irregular heat patterns in devices, events, and processes before failures occur. The ultracompact IR camera accepts interchangeable lenses and features high-resolution IR video, extensive output functionality, and locally or remotely configurable logic. Camera is web-enabled and provides for remote monitoring, multivariable alarms, and advanced control capabilities, which include autonomous reaction to programmable thermal parameters. Up to four target spots are configurable locally and remotely. Unit also includes six alarming functions, real-time scan speed, composite video out, and wide range of I/O signal options. Applications include remote substation/underground vault monitoring, process control, machine vision, and advanced security functions.
FLIR Systems flirthermography.com Write 304 on PE card
IR sensor/transmitter
OS136 model miniature, low-cost, infrared (IR) sensor/transmitter features aard outputs that interface directly and easily with meters, controllers, dataloggers, recorders, computer boards, and PLCs.
OMEGA Engineering, Inc. omega.com Write 300 on PE card
Improved pen arm
Improved pen arms are available for the company’s 4-in. temperature and 4-in. pressure chart recorders. Product improvement features updated design pen arm for faster and easier pen and paper changes. New arm lifts completely off the chart, allowing replacement, then snaps back into place for accurate recording.
The Dickson Co. dicksonweb.com Write 301 on PE card
Smart color sensors
SpectroCam uses an internal spectrograph to split incoming light into its constituent wavelengths. Complete spectrum of a sample can be learned and small deviations detected. Sensor system is highly sensitive to color and has unlimited color-learning capabilities.
DVT Corp. dvtsensors.com Write 302 on PE card
SCR power controller
The 7300A 3-phase silicon controlled rectifier (SCR) power controller is rated at 16—40 A, 100—500 Vac, with a 0—5-Vdc, 0—10-Vdc, or 4—20-mA control input. The controller offers zero-cross firing for fixed resistance loads or phase-angle firing for inductive and variable resistance loads.
Invensys Eurotherm eurotherm.com Write 303 on PE card
Clamp meter
Model 200 clamp meter measures ac current to 400 A, ac/dc voltage to 600 V, and resistance to 20 Mh. Features include high resolution, 3ductors up to 300 MCM. Clamp meter also comes with test leads.
Extech Instruments Corp. extech.com Write 305 on PE card
Automation site relaunch
Relaunched web site features easy navigation and organization according to industries served, which include electronics, pharmaceuticals, automotive, paper converting, and others. The layout of the site invites first-time visitors to navigate through pages from the top, while providing direct links to industry applications for users familiar with the site. The site contains products, applications, and company profile.
FlexLink Systems, Inc. flexlink.com Write 306 on PE card
