Instruments – 2000-11-01
Pressure regulator minimizes contamination IR4000 Series pressure regulator has no internal threads, minimizing the risk of particulate contamination. A dual screen/filter further enhances performance.
By Staff November 1, 2000
IR4000 Series pressure regulator has no internal threads, minimizing the risk of particulate contamination. A dual screen/filter further enhances performance. The screen is a 100-micron wire mesh and the filter is a 10-micron sintered metal element in the inlet port. It uses a compression member to secure the poppet in place. Veriflo Div., Parker Hannifin Corp.; www.veriflo.com
TO VOTE, WRITE 88 ON BALLOT
For more information, circle 88 on card
Calibrator operates with or without PDA
PDA calibrators use commercially available personal digital assistants (PDAs) for a common interface with an intuitive touch screen, eliminating the need for buttons and knobs. The calibrators can source and read common process signals. The PDA can be used independently of the calibrator backpacks. Data may be shared with a desktop computer for reports or a certification of calibration. Transmation Products Group; www.transmationinc.com
TO VOTE, WRITE 114 ON BALLOT
For more information, circle 114 on card
Handheld system measures thermally and visually
ThermaCAM PM 695 is a handheld system that includes both thermal and visual imaging capabilities in a single product. It features automatic focusing, high thermal sensitivity, and temperature measurement tools. It records and stores temperature analysis data, as well as voice and text comments along with thermal and visual images. It automatically documents inspection results and can be used for predictive maintenance. FLIR Systems, Inc.; www.flir.com
TO VOTE, WRITE 141 ON BALLOT
For more information, circle 141 on card
Temperature transmitter isolates electronics
THZ Smart HART temperature transmitter features a dual compartment and display. The dual compartment allows access to the electronics without taking the unit out of service. An isolation seal protects the instrument from humidity, moisture, and corrosive materials potentially brought in through conduit entries. A glass window built into the front cap allows viewing of process status in the field. Moore Industries-Intl., Inc.; www.miinet.com
TO VOTE, WRITE 190 ON BALLOT
For more information, circle 190 on card
Water sensor eliminates lab testing
WS04 portable water sensor measures percent water saturation level and temperature of fluids without lab testing. It allows the user to take corrective action before free water appears, potentially damaging equipment or contaminating processes. It is a portable, battery-powered unit allowing access to varied sampling points. Pall Corp.; www.pall.com/contaminationcontrol
TO VOTE, WRITE 206 ON BALLOT
For more information, circle 206 on card
Handheld detector checks motor rotation
Detector identifies rotation direction of 60-Hz ac motors quickly and safely. It uses a microprocessor and circuitry capable of sensing the magnetic field of an energized motor and identifies its direction of rotation. The light emitting diode display indicates rotation direction. This handheld unit uses a 9-V battery. Bell & Gossett; fhs.ittind.com
TO VOTE, WRITE 213 ON BALLOT
For more information, circle 213 on card
