Continue to Site
Inlet keeps hydraulic tanks clean
Replacing conventional filler/breathers with the OilMiser FILLorDrain inlet establishes a permanent down pipe for filling or draining hydraulic reservoirs.
By Staff February 1, 2000
Replacing conventional filler/breathers with the OilMiser FILLorDrain inlet establishes a permanent down pipe for filling or draining hydraulic reservoirs. Once installed, the potential danger of a bottom outlet and the need to open the reservoir and insert a suction wand are eliminated. The replaceable, high efficiency air filter remains effective against contamination before, during, and after any maintenance procedure.
JLM Systems, Ltd.
www.oilmiser.com
Circle 386
