Infrared imaging system
The GS110 process imaging system for low emissivity glass is designed to monitor one-side coated flat glass. The system can also be used for non-contact infrared temperature measurement in other secondary glass-processing applications such as bending, forming and annealing. It features an automatic correction mode that adjusts the system to accommodate changes in emissivity due to different gla...
The GS110 process imaging system for low emissivity glass is designed to monitor one-side coated flat glass. The system can also be used for non-contact infrared temperature measurement in other secondary glass-processing applications such as bending, forming and annealing. It features an automatic correction mode that adjusts the system to accommodate changes in emissivity due to different glass types or coatings. An OPC server is integrated with proprietary software, allowing seamless integration of data into other process control software packages. An automatic database function facilitates continuous documentation of product quality, with data stored as a profile or thermal image to be archived and printed for subsequent analysis.
Raytek
www.raytek.com
