Inductive proximity sensors
APS series inductive proximity sensors are fitted with polycarbonate unshielded housings and LED status indicators.
By AutomationDirect February 10, 2015
APS series inductive proximity sensors are fitted with polycarbonate unshielded housings and LED status indicators. Courtesy: AutionmationDirectAPS series inductive proximity sensors are IP67-rated rectangular compact DC sensors available in top or front sensing models with 2.5mm and 4mm sensing ranges. Come with two-wire or three-wire configurations, the 10 to 30vdc high-frequency oscillation type sensors are fitted with polycarbonate unshielded housings and LED status indicators. The APS series is available with normally-open or normally-closed NPN, normally-open PNP or normally-open NPN/PNP outputs. These sensors have an embedded two-meter connection cable.
AutomationDirect
www.automationdirect.com
