Incremental encoder
The DFS 60 high-resolution incremental encoder features hollow and blind hollow shaft clamping, a radial or axial cable outlet, an integrated stator coupling in spring steel, a large distance between ball bearings and a maximum of 65,536 lines. Electrical isolation between motor shaft and encoder increases interference immunity and reliability.
The DFS 60 high-resolution incremental encoder features hollow and blind hollow shaft clamping, a radial or axial cable outlet, an integrated stator coupling in spring steel, a large distance between ball bearings and a maximum of 65,536 lines. Electrical isolation between motor shaft and encoder increases interference immunity and reliability. The nickel code disc is designed for increased robustness and a high temperature tolerance for heavy duty industrial applications such as printing, textile, woodworking and packaging machines.
SICK STEGMANN Inc. : www.stegmann.com
