Continue to Site
Illumination
By Staff March 10, 2005
New LED offering
Luxeon high-power LED family is being expanded. The new emitters offer up to 65 lumens in white at 350 mA, 185 C allowable junction temperature, and a JEDEC moisture sensitivity level of 2a, which allows extended unsealed life before final packaging. The redesigned Luxeon package reduces heat sink requirements, delivers more light at comparable ambient conditions, expands use in higher temperature conditions, and allows higher current operation.
Lumileds Lighting lumileds.com Write 315 on PE card
DALI ballasts
DaliPro is a user-friendly, dimmable ballast designed for use with DALI controls. Digital addressable lighting interface (DALI) is the new industry standard for digital communications between ballasts and control systems. These ballasts can be programmed to perform multiple commands such as on-off, light level control, and scene recall on cue from the push of a button or by computer control. Units can be controlled individually, in groups, by room, or by area.
Universal Lighting Technologies, Inc. universalballast.com Write 316 on PE card
Ballast upgrade
Centium HCN-4S54-90C-2LSG electronic ballast line has been expanded to include a 4-lamp model for 54-W T5/HO applications. Ballasts include Intellivolt-Hi technology, which enables 347—480-V operation. Its 480-V operation eliminates the need to rewire another mains voltage. A high-low switching option allows switching among lamp configurations, while its semi-independent lamp operation (ILO) ensures that the fixture will remain partially lit if a lamp fails.
Advance Transformer Co. advancetransformer.com Write 317 on PE card
LED illumination
SLL003 series ultra slim shoebox LED cluster light module uses only 20 W, but can replace 75-W HPS fixtures. Light module features 400 white 5 mm LEDs mounted on a printed circuit board (PCB), consumes only 20 W, emits 656 candela of light, and gives off 700 lumens. The light module operates on voltages from 85—265 V ac, allowing seamless integration into existing wiring systems. Optional LED colors are red, green, orange, yellow, cool white, and blue.
LEDtronics, Inc. ledtronics.com Write 318 on PE card
Lighting catalog
The 2005 Ruud Lighting full-line catalog is now available. The 300-page color catalog contains detailed product descriptions and photos, performance photometrics, and application photography. Featured new products include compact fluorescent high bays, expanded selections in the exit/emergency and track categories, and redesigned optical systems for area cutoff and parking/roadway fixtures.
Ruud Lighting ruudlighting.com Write 319 on PE card
Work light brochure
Wobble Light brochure contains easy-to-read grids, testimonials, and informative product details about the self-righting work light that bounces back from abuse. Brochure illustrates features such as impact-resistant polycarbonate dome, internal ventilation system, floating shock system, counter-weighted design, and power outlet for connecting power tools or additional Wobble Lights.
Wobble Light, LLC wobblelight.com Write 320 on PE card
