Hole cutters come with quick-change feature
Kwik Change carbide-tipped hole cutters produce openings from 5/8-3 in. The cutter heads are changed with a simple push and turn, allowing the same arbor to be used for multiple sizes. An ejector spring makes removal of a slug easier.
By Staff November 1, 1999
Kwik Change carbide-tipped hole cutters produce openings from 5/8-3 in. The cutter heads are changed with a simple push and turn, allowing the same arbor to be used for multiple sizes. An ejector spring makes removal of a slug easier. Three and five-piece kits, including cutter heads, arbor, and hex key, are available.
Greenlee Textron; www.greenlee.textron.com
TO VOTE, WRITE 123 ON BALLOT
For more information, circle 62 on card
