High-temperature ball bearings
Deep Groove ball bearings for high-temperatures can operate reliably in extreme conditions and often can eliminate a need to specify expensive special bearings or costly lubricants.
Deep Groove ball bearings for high-temperatures can operate reliably in extreme conditions and often can eliminate a need to specify expensive special bearings or costly lubricants. The bearings are designed for industrial applications, including kiln truck wheels, support rollers, general wheel arrangements and other equipment where bearings will be subject to temperature demands. The series features five designs that incorporate unique cage materials and designs, lubrication systems and seal arrangements. Bearing sizes range from 0.3937 inch to 3.9370 inch bore diameter, and temperature ranges from 238 F to 662 F.
SKF USA Inc ., www.skfusa.com
