Continue to Site
High-pressure coolant pumps
The MP-B series features Hydra-Cell diaphragm pump technology. With a hydraulically balanced design, the fixed or variable volume high-pressure coolant pumps are built to handle abrasive particles found in machine tool coolant. Positive displacement allows users to adjust flow rate by changing the speed of the pump shaft.
By Plant Engineering Staff December 15, 2007
The MP-B series features Hydra-Cell diaphragm pump technology. With a hydraulically balanced design, the fixed or variable volume high-pressure coolant pumps are built to handle abrasive particles found in machine tool coolant. Positive displacement allows users to adjust flow rate by changing the speed of the pump shaft. The unit is portable, even with its 50-gallon reservoir filled. The pumps’ electrical components are certified to meet UL, CSA and CE standards.
MP Systems www.monsterswiss.com
