High-pressure connector for extreme subsea applications
Ametek Subsea Interconnect's Elite Series WetMate 3-channel connectors are high pressure, high-temperature (HPHT) designed to operate in extreme environments such as subsea and downhole oil and gas applications. The HPHT connector is 15.8mm in diameter and has been tested to 1034 bar and temperatures up to 150 C.
Ametek Subsea Interconnect’s Elite Series WetMate 3-channel connectors are high pressure, high-temperature (HPHT) designed to operate reliably in the extreme environments such as subsea and downhole oil and gas applications. The HPHT connector is 15.8mm in diameter and has been tested to 1034 bar and temperatures up to 150 C. The Elite Series Wet-Mate connector communicates through electrical signals from downhole pressure and temperature sensors in subsea oil and gas environments. The Elite Series Wet-Mate connectors feature concentric contacts that are individually sealed within pressure-balanced, oil-filled plug and receptacle connector housings to protect both plug and socket contacts from the external seawater environment along with repeated subsea mating capability at extreme pressures and temperatures.
www.ametekinterconnect.com
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
