High-density fuse terminal blocks
These double-level fuse terminal blocks incorporate reliable screw connection in a 6.2-mm pitch.
By Phoenix Contact May 14, 2015
These double-level fuse terminal blocks incorporate reliable screw connection in a 6.2-mm pitch. Courtesy: Phoenix ContactThe UT 4-PE/L/HESI fuse terminal block series multi-level terminal blocks provide fusing, feed-through, and shielding functionality. These fuse terminal block series incorporates reliable screw connection in a 6.2-mm pitch. The double bridge shaft on each level allows quick installation of potential distribution. The UT line eliminates screw back-out and delivers termination of stranded wire, with or without ferrules. It is rated for multi-conductors. In addition to CID2 certification, the terminal blocks also have approvals for: Class I, Zone 2, EX, IEC EX UL, cUL, AEX nA II Gc with current ratings of 20 A and 300 V UL.
Phoenix Contact
www.phoenixcontact.com
