Heating, Ventilating, and Air Conditioning
Adsorber offers high first-pass removal efficiency Vari-Klean ultra high-efficiency gas phase adsorber offers high (90%) first-pass removal efficiency.
By Staff November 1, 2000
Vari-Klean ultra high-efficiency gas phase adsorber offers high (90%) first-pass removal efficiency. Unit features high carbon loading (600 gr/sq m), high activity carbon (less than 1.5% of the surface area is blinded), and low resistance. Filter is designed for continuous removal of airborne molecular contamination less than 500 ppb. Airguard; www.airguard.com
TO VOTE, WRITE 26 ON BALLOT
For more information, circle 26 on card
Self-cleaning hydronic boiler features 87% efficiency
Pulsar oil-fired, pulse combustion hydronic boiler offers 87% efficiency, self-cleaning burner, cast iron combustion chamber, and digital touchpad control. Unit is UL, MEA, and BAR approved. Complete oil combustion yields lower fuel and maintenance costs. Environmentally friendly system is quiet, soot-free, clean burning, and easy to install. Patterson-Kelley/Harsco; www.pkboilers.com
TO VOTE, WRITE 39 ON BALLOT
For more information, circle 39 on card
Dye injector simplifies leak detection
BigEZ multi-dose fluorescent leak detection dye injector treats up to 16 gal. of lubricant (approximately 400 lb of refrigerant or 150 tons of cooling). Technician simply hooks up the unit and turns the handle to inject the exact amount of dye required. Super-concentrated, solvent-free, lubricant-specific dyes are safe for any size AC/R system, and are approved by most major manufacturers. Spectronics Corp.; www.spectroline.com
TO VOTE, WRITE 55 ON BALLOT
For more information, circle 55 on card
Water heater links to building management systems
Intelli-Fin boiler/water heater incorporates LonWorks technology to enable the unit to integrate into building management systems over an open network. A digital display permits access to more than 21 data points, including mode of operation and total run time. Remote monitoring and control access are available over phone lines. Lochinvar Corp.; www.lochinvar.com
TO VOTE, WRITE 67 ON BALLOT
For more information, circle 67 on card
Two-stage trap ideal for limited spaces
APT14 automatic pump trap is half the size of other versions, making it ideal for applications with limited installation space. Trap provides a compact solution for removing condensate from steam heat exchangers and process plants under all operating conditions, even vacuum. Device is available as a standard unit for all steam pressures up to 200 psig. Spirax Sarco, Inc.; www.spiraxsarco-usa.com
TO VOTE, WRITE 75 ON BALLOT
For more information, circle 75 on card
Quartz heaters use thick film technology
Thick film quartz heaters provide a superior method for semiconductor wet chemistry applications. Intended for deionized and aggressive chemicals, the modules offer ultra pure semiconductor-grade quartz performance, replacing inefficient infrared quartz heater output. Use of semiconductor-grade quartz avoids the permeability problems of Teflon-coated products. Watlow; www.watlow.com
TO VOTE, WRITE 87 ON BALLOT
For more information, circle 87 on card
Low-profile deaerator features space saving design
Low-profile, vertical, tray-type deaerator features a compact, space saving design. Package is lower in height and requires less floor space than other major deaerators, yet has all the high-performance design features of larger units. System works with a true 1-ft NPSH pump to achieve unparalleled height savings. Bryan Steam LLC; www.bryanboilers.com
TO VOTE, WRITE 104 ON BALLOT
For more information, circle 104 on card
Fax logger records temperature and humidity data
FX420 remote location fax logger automatically records and transmits a graphical history of temperature and humidity levels at the installed location. Data is retrieved by fax or e-mail. System eliminates the need to have personnel check conditions at remote sites, change chart paper, download data, or dial in for information. Temperature range is 0-100 F; humidity range is 0-95%. Dickson; www.dicksonweb.com
TO VOTE, WRITE 143 ON BALLOT
For more information, circle 143 on card
