Heating, Ventilating & Air Conditioning
Click on the above link to see Product of the Year finalists in this category.
Note to our readers: Product of the Year finalists are listed below. To view the products, please download this pdf file , and this one . They will take a minute or two to
Flashlight detects AC&R leaks
Titan Stinger is a cordless AC&R fluorescent leak-detection flashlight. Designed with dichroic filter lens technology, the unit produces significantly more UV/blue light than other inspection flashlights. The flashlight is 73/8-in. long, weighs 8.7 oz., and has an effective working range of at least 12 in., depending on ambient light. A rechargeable NiCad battery provides about an hour of inspection time. Spectronics Corp.; www.spectroline.com
TO VOTE, WRITE 49 ON BALLOT
For more information, write 49 on card
Shatter-resistant lamp kills germs
UVC Emitters are shatter-resistant, plastic-sheathed lamps for mold and microbial control in critical processing applications. The beverage and pharmaceutical-grade tubes continuously eradicate mold, bacteria, and phlage (bacteria attacking viruses) in formerly impossible places. A resin coating encapsulates the tube with no loss of UVC output. Steril-Aire, Inc.; www.steril-aire-usa.com
TO VOTE, WRITE 84 ON BALLOT
For more information, write 84 on card
Combustion system quickly responds to process changes
Magna-Flame LEx Rapid Response System is an ultralow NOx and CO combustion system that incorporates integral control components into the burner platform to provide the primary benefits of ultralow emissions, fast changes to process requirements, and low operating costs. The system can respond to process changes in less than 10 sec. North American Mfg. Co.; www.namfg.com
TO VOTE, WRITE 194 ON BALLOT
For more information, write 194 on card
Leak detector has dual functions
Informant 2 leak detector allows pinpoint detection of both refrigerant and combustible gases. Sensor tips swap in seconds and automatically adjust sensitivity levels. The unit features an audible indicator with mute option coupled with sequential LEDs to monitor increasing gas concentrations. A flashing light at the tip visually defines the sampling location. Bacharach, Inc.; www.bacharach-inc.com
TO VOTE, WRITE 22 ON BALLOT
For more information, write 22 on card
System remotely analyzes boiler failures
Miura Online Maintenance can predict a boiler’s maintenance needs from information the boiler continuously reads and records. The system automatically calls should a connected boiler go down, pinpointing which alarm occurred and which of 28 possible faults was the cause. Everything that happened in the boiler for 4 sec before the shutdown is recorded. Miura Boiler Co., Ltd.; www.miuraboiler.com
TO VOTE, WRITE 77 ON BALLOT
For more information, write 77 on card
Draft control eliminates microorganisms
Control-A-Flow draft eliminator with antimicrobial filter is the solution to air conditioning vents blowing cold/hot air laden with germs and allergens. While filtering and killing microorganisms, it deflects air along the ceiling, maintaining balance and air volume. The device installs in seconds without tools and can be adjusted while standing on the floor. International Diversified Marketing; www.controlaflow.com
TO VOTE, WRITE 80 ON BALLOT
For more information, write 80 on card
Burner package has ultralow NOx emissions
CSB microSTAR is an ultralow NOx burner package for heating and steam applications. It is UL listed with a firing range of 2.0-10.5 MMBtu/hr. The package achieves the low emissions of less than 12 ppm reliably by premixing air and fuel and combusting this mixture on a high-temperature, alloyed surface. The package does not require complex combustion controls or flue gas recirculation. Alzeta Corp.; www.alzeta.com
TO VOTE, WRITE 183 ON BALLOT
For more information, write 183 on card
Enclosure protects shop computers
Foundation is an integrated and adaptive PC enclosure with the flexibility to be scaled up in features and levels of protection from a durable rack enclosure to a fully integrated mini computer room system. Complete HVAC, humidification/
dehumidification, and power protection can be added. Units can be customized with adjustable mounting rails, multiple door options, and cable access. Liebert Corp.; www.liebert.com
TO VOTE, WRITE 188 ON BALLOT
For more information, write 188 on card
Alarm deciphers emergency messages
FSNetworx is a safeguard monitoring and alarm system that sends flame malfunction information via email and wireless devices from multiple remote plants and boiler houses to decrease downtime due to burner equipment failures. It provides web-based monitor and diagnostic displays for easy diagnosis of problems. Users can prioritize alarms. Total Automation Concepts; www.fsnetworx.com
TO VOTE, WRITE 60 ON BALLOT
For more information, write 60 on card
