Continue to Site
Heat exchangers
A new line of heat exchangers are made with the industry's highest density fins, allowing the liquid to be cooled to lower temperatures.
By Advanced Thermal Solutions, Inc. August 14, 2017
A line of tube-to-fin, liquid-to-air heat exchangers are made with the industry’s highest density fins to maximize heat transfer from liquid to air, allowing the liquid to be cooled to lower temperatures than other heat exchangers on the market. The heat exchanger fins and tubes are made of copper and stainless steel to be suitable for a variety of fluids, including water, dielectric fluids, and custom-designed heat transfer fluids. Each of the seven heat exchanger sizes is available with or without a fan. A heat exchanger is a device that allows heat from a fluid (either a liquid or a gas) to pass to another liquid or gas without the two fluids having to mix or come into direct contact. Lengths range from 5.8 to 21.9 in., widths from 5.8 to 14 in., and heights from 1.8 to 2.6 in. Tube diameters are available at 0.375 and 0.5 in.
www.qats.com
