Hand-vacuum suction cups
Industrial-duty hand-vacuum suction cups, suitable a variety of products and materials, are offered in more than 40 varieties for applications ranging from assembly to installation operations.
By Plant Engineering Staff February 29, 2008
Industrial-duty hand-vacuum suction cups for handling steel plate and sheet, fiberglass, flooring, glass, countertops, stone tiles, and other non-porous products are offered in more than 40 varieties for applications ranging from assembly to installation operations. Built for industrial use, they include air-operated suction cups, lever-actuated cups, and pump-style vacuum cups that provide up to 125 pounds of holding power. Compressed air-powered vacuum hand cups operate on 80 psi. Lever-actuated cups incorporate two 43/4-inch diameter rubber suction cups, and the pump-style can also be equipped with a turn-buckle assembly.
Anver Corp.
www.anver.com
