Guide to shaft couplings
The basic function of a coupling is to connect two shafts, end-to-end, inline, for the purpose of transmitting torque or power from one shaft to another, causing both to rotate in unision. This article details the types, advantages and limitations of shaft couplings.
Types
Advantages
Limitations
The basic function of a coupling is to connect two shafts, end-to-end, inline, for the purpose of transmitting torque or power from one shaft to another, causing both to rotate in unison. If the shafts are perfectly aligned, there is no problem in using rigid couplings. Flexible couplings are able to compensate for minor amounts of misalignment and random movement between the two shafts. They are commonly used in industrial applications.
Such compensation is vital because perfect alignment of two shafts is extremely difficult and rarely attained. If not properly compensated, minor shaft misalignment can result in unnecessary wear and premature replacement of other system components. Flexible couplings can, in varying degrees, minimize the effect of misaligned shafts.
In certain cases, flexible couplings are selected for other protective functions as well. They provide a breakpoint between driving and driven shafts that acts as a fuse if a severe torque overload occurs. This breakpoint ensures that the coupling fails before something more costly breaks elsewhere along the drive train. Flexible couplings can dampen torsional vibration that occurs naturally in driven equipment.
Each type of coupling has some advantage over another type. There is no single coupling that can “do it all.” There are tradeoffs associated with each design, including initial cost. Each type has strengths and weaknesses that must be taken into consideration, because they can dramatically impact how well the coupling performs.
Plant Engineering magazine extends its appreciation to the Power Transmission Distributors Association (PTDA), Lovejoy, Inc., and TB Wood’s, Inc., for the use of their material in the preparation of this article. This article includes excerpts from the Power Transmission Handbook published by PTDA. The handbook is a primer on power transmission/motion control products and applications. The handbook is available from PTDA at 312-876-9461 or at www.ptda.org/catalog.
— Joseph L. Foszcz, Senior Editor, 630-320-7135, jfoszcz@cahners.com
Types
Advantages
Limitations
Elastomeric couplings Advantages
Torsionally soft
No lubrication or maintenance
Dampens vibration and absorbs shock
Field replaceable elastomers
Low reaction load on bearings
Handles large misalignment
Low cost for a given bore size
Limitations
Sensitive to chemical sand heat
Low power density
Not suited for positive displacement
Difficult to balance
Some types have poor overload capacity
Coupling evaluation factors -
Adaptability of design
Alignment capabilities
Axial freedom
Backlash
Chemical resistance
Damping capacity
Ease of installation
Fail safe
Field repairable
High speed capacity
Maintenance required
Number of parts
Reactionary loads from axial forces
Reciprocating driver and load
Temperature sensitivity
Torque capacity to diameter
Torque overload capacity
Metallic couplings Advantages
Torsionally stiff
Good heat capability
Good chemical resistance
High power density
High speed and large shaft capability
Zero backlash in many types
Low cost per unit of torque transmitted
Limitations
Fail in fatigue or wear
May need lubrication
Often, many parts to assemble
Most need careful alignment
Poor vibration damping and shock absorption
Electrically conductive, unless modified
