Grease dispensers
An alternative to manual lubrication, Streamliner grease dispensers provide variable feed rates and can feed up to eight lubrication points.
An alternative to manual lubrication, Streamliner grease dispensers provide variable feed rates and can feed up to eight lubrication points. They provide precise metering of lubricant in remote areas and are equipped with electro-mechanical drives, allowing them to adapt to a range of grease applications. The dispensers have reservoir capacities of up to 500 cc and high operating pressures to flush contaminants out. A UL explosion-proof unit is available. Trico Corp. www.tricocorp.com
