Continue to Site
Gas leak detector
The OptoAcoustic GLD-OA-01 gas sensor comprises two identical cells that act interchangeably either as a primary gas-measurement cell or as a secondary compensation cell. The dual-cell design eliminates the need for calibration. The secondary cell provides an active sensing element and a backup sensing element within one unit.
By Plant Engineering Staff October 15, 2008
The OptoAcoustic GLD-OA-01 gas sensor comprises two identical cells that act interchangeably either as a primary gas-measurement cell or as a secondary compensation cell. The dual-cell design eliminates the need for calibration. The secondary cell provides an active sensing element and a backup sensing element within one unit. Compensation algorithms provide immunity from up to 95% humidity and temperatures under 150 F. The device is capable of continuously monitoring combustible gas leaks from 0% to 100% of the lower explosion limit.
Carthago International Solutions Inc.
www.carthargois.com
