Continue to Site
Frequency inverter simplifies motor wiring
Movimot geared motor with built-in variable frequency inverter replaces the existing terminal box, reducing complicated wiring and simplifying installation and maintenance.
By Staff February 1, 1999
Movimot geared motor with built-in variable frequency inverter replaces the existing terminal box, reducing complicated wiring and simplifying installation and maintenance. This cost effective, total drive solution is well suited for decentralized and centralized applications. In decentralized operations, the speed of each drive is electronically adjusted without the use of a central controller. For centralized applications, as many as 31 individually tuned and adjusted drives can be controlled by one RS-485 master.
SEW-Eurodrive
www.seweurodrive.com
Circle 371
