Continue to Site
Flush cutter
The LX-T micro-shear flush cutter features a precision tip that is tapered to reach into tight spaces and produce a clean, square cut on soft wire up to 20 AWG (0.8 mm). Designed with an ergonomic handle, cushioned rubber grips and a light-touch return spring, the rugged cutter has precision-ground, high-carbon-steel blades that are heat treated to Rc 55–57 C.
By Staff October 1, 2006
The LX-T micro-shear flush cutter features a precision tip that is tapered to reach into tight spaces and produce a clean, square cut on soft wire up to 20 AWG (0.8 mm). Designed with an ergonomic handle, cushioned rubber grips and a light-touch return spring, the rugged cutter has precision-ground, high-carbon-steel blades that are heat treated to Rc 55—57 C. Capable of performing millions of cuts, the flush cutter employs the firm’s patented bypass cutting technology, which requires less effort than conventional, compression-type cutters. Static control grips are optional, and models with lead retainers are available.
Xuron Corp.
www.xuron.com
