Flowmeter offers easy setup
A self-contained flow transmitter can be set up before installation without requiring actual flow. The operator simply selects the appropriate flow range from the transmitter's setup menu; no further programming or calibration is required.
By Staff July 1, 1998
A self-contained flow transmitter can be set up before installation without requiring actual flow. The operator simply selects the appropriate flow range from the transmitter’s setup menu; no further programming or calibration is required. The device uses the calorimetric principle to provide a linear 4-20 mA analog signal directly proportional to the flow rate in gpm. The transmitter can be adjusted for operation in five ranges from 0-2 up to 0-50 gpm.
efector, inc.
