Float system
The Multi-Flow Series float system is a single-point watering system for flooded, lead acid batteries. It comprises a group of patent-pending valves connected by plastic tubing, replacing battery vent caps. To operate, a water-supply is attached to a quick-connect fitting on one end of the tubing. Water subsequently flows through the tubing to each battery cell, and as the cells reach the desig...
The Multi-Flow Series float system is a single-point watering system for flooded, lead acid batteries. It comprises a group of patent-pending valves connected by plastic tubing, replacing battery vent caps. To operate, a water-supply is attached to a quick-connect fitting on one end of the tubing. Water subsequently flows through the tubing to each battery cell, and as the cells reach the designated fill level, the valve shuts off.
Liquid Precision, Inc. : www.liquidprecision.com
