Continue to Site
Flex-block system
The Flex-Block plinth/base assembly is designed for free-standing enclosures and liquid cooling packages and its modular design allows for easy assembly
April 19, 2013
The Flex-Block plinth/base assembly is designed specifically for free-standing enclosures as well as liquid cooling packages. The Flex-Block design makes it possible to quickly clip together the plinth/base components and attach accessories like casters, leveling feet and cable management pieces without special tools. The base/plinth system comprises four corner modules and covers made of strong, fiberglass reinforced plastic, plus sheet steel side trim panels. The modular design and increased assembly space allow the four corner pieces, which support the entire weight of the enclosure, to be quickly and easily fitted underneath the enclosure.
Rittal
www.rittal.com
